Old Feb 16, 2022 | 10:23 AM
onehundred80
Default Re: My double din install adventure
Originally Posted by crowz
With the way the wires are routed on mine the double sided tape stuff should hold it in place as nothings pulling on it. I would of liked to of used the metal plate under the insulation and had the magnet hold it if it was the magnetic type normally included with the pioneer radio. But with the aftermarket one the refurbish place used I had to do the tape route. I imagine gluing a strip of wood like you did will keep it from sliding anywhere.
I believe the glue gets hot and under braking the weight of the antenna makes it inch forward.
