Old Feb 21, 2022 | 04:16 PM
CL770's Avatar
CL770
Default Re: Drag Specific TCU Tune
Originally Posted by amx1397
I do not see a 305/30-20 in my book,, but here are some 295/30-20 is 11.6 wide 3.5 sidewall 27"tall it will fit
305/25-20 is 12"wide 3.0sw and 26"tall ,,255/30-20 is 10 w 3.0sw 26tall 255/35-20 10w 3.5sw 27tall 325/25-20 12.8w 3.2sw 26.4 tall ,,335/25-20 13.2w 3.3sw 26.6 tall and345/25-20, 13.6w 3.4sw 26.8 tall (stock 19" is 255/35-19 10"wide 3.5 sw 26"tall)
any tire with under 260 wear will stick 70 to m80% 200 will stick with a 20" tire about 85 to 90% in this video the tires are close to 100 wear drag radials this was 2013
for street and maybe 2 times a month at the track the stock converter is good
https://www.youtube.com/watch?v=M2b7wbJog9E
Thanks for the info on the tyres. The tyres I have now are: Nankang Noble Sport NS20 285/30-20 (26.8") with treadwear 240 (so not very sticky), NS-20 | Nankang Tyres and I was looking at: Nankang NS2R 305/30-20 (27.4") semi slick with treadwear 120 NS-2R | Nankang Tyres (not sure if 27.4 will fit), but a good 295/30-20 might be a solution (what brand was that?). What tyre pressure do you typically run on the street tyres (at the track)? When you say "stock converter" which converter do you mean, the NA V6 converter, the SRT6/V8 converter, or the M113K converter? They will all fit but have different characteristics. The reason I ask is because, when I had my M113K converter rebuilt, I asked about potentially modifying it's stall speed. They said that the simplest solution would be to use the smaller V6 converter, it would spin up quicker, have a slightly higher stall speed (if I didn't lock it up first with the TCU) and that it had the same clutch inside it as the M113K converter.. Sorry for all the questions.
