Thread: Big Thanks!
Old Feb 22, 2022 | 10:01 AM
Derekw66's Avatar
Derekw66
Default Big Thanks!
I just wanted to say thank you to everybody on the forum. Thanks for all of your articles, troubleshooting tips and pictures, I solved 98% of all of my issues on my recently acquired basket case. Just some of my issues:
Both front inner fenders and inner corners, right front headlight, idler pulley, spark plugs, front and rear pads and rotors, water pump, hood release handle, center console, fog lights, grill, lower grill guards, steering linkage, two front rims, two front tires, driveshaft support bearing, steering stabilizer, both lower ball joints, mass airflow sensor, both front springs, rocker panel brackets, wheel sensor, ABS control module which fixed my brake light, ABS light, Bas light, speedometer, odometer, rear wing stuck up, rear wing switch flashing and I’m sure one or two other lights. Relay control module, thermostat housing and thermostat . Also changed manual transmission and rear end fluid with the obligatory engine oil, coolant and brake fluid purge.
Without this forum, this car would not of been back on the road. It was destined for parts only. Now it’s my daily driver and will get a new coat of paint soon enough. It survived thanks to you guys, so thank you.
