Old Feb 24, 2022 | 03:38 PM
GraphiteGhost
Default Re: Trunk light fuse
Originally Posted by P-J
Thanks guys, much appreciated...raining and 38 degrees here today, I will check it tomorrow and let you know if this fuse is the culprit.
Have you checked both trunk lamp terminals to ground, to see IF there is 12v (nominal) on a voltmeter? With one door open, normally, you should get system voltage on one of them terminals. If not, an open circuit or fuse is suspect. Does your dome light come on when the door opens? If so, then you should have that 12v (nominal) at one of the two terminals (to a good ground point). I would not use the other terminal for the ground because it could be 'open'. Good luck!
