Old Feb 26, 2022 | 10:57 AM
Jack G's Avatar
Jack G
Default Re: Trunk light fuse
Did you check the presence of voltage across the lamp contacts? This will indicate if your fuse is blown even if you do not know its location. Also, check to see if lamp holder wire connections are good. You might also want to check the switch that turns on the light.
Have you ever considered installing a second lamp? I did and it improves visibility considerably.
