Old Feb 26, 2022 | 06:46 PM
Ant92994's Avatar
Ant92994
Default Two injector code
Hi I’m at my wits end at the moment. I’m having two misfire codes and two injector codes on the same cylinders. I swapped everything already. If I go to the ecu c4 connector where all the fuel injector wires go into and wiggle it the car will literally shut off. Is their a way to fix the pins in there or do I need a new harness ? Has anyone experienced this. The car drives .
