Re: Two injector code
It was c4 connector . Had to remove the external housing with the clip on it and connect it that way check engine light immediately off. I was more concerned about replacing it or a fix not a diag as much. So if anyone is ever throwing injector codes and misfires and you’ve already swapped everything and double checked the wires. Make sure your getting a good connection there.
