Re: Has anyone tried the ArtiDiag800BT scan tool
If you purchase the Foxwell in years past you could get two downloads for it for the initial cost. After that you can add more programs for up to I believe four makes on the one scan tool. That may help you with some of the other makes/models of cars you have. The Foxwell when scanning A Crossfire goes thru something like 25 system ( scanning as a Mercedes R170), but it can only find 18 or something like that when used on a Crossfire as the systems are different between the two cars. I have no idea what it can or can't find in the way of the roadsters roof; I would think the SLK hard top and the Crossfires rag top are different switch and hydraulically. I also have a 2005 CLK 500 and the Foxwell works really well with it, scanning something like 39 systems. Don't get the Chrysler down load as it is useless with the Crossfire; use the Mercedes. The Foxwell is a lot of tool for the money, but nothing like a DRB III emulator if you can figure out how to get that to work it seems to be the best, for the least amount of money.
