Old Mar 3, 2022 | 01:16 PM
  #46 (permalink)
Dpalmer22's Avatar
Dpalmer22
Default Re: Convertible Top Sensors
[QUOTE=MCPO;966158]HELP,
Are there any videos available showing how to replace the remove and replace LATCH RETAINER SWITCH located above the driver side visor?
This is all that I know of for instructions https://www.crossfireforum.org/forum...-roadster.html. Before you go through all that work, have you checked it for voltage where it plugs into the PTCM? Should be either zero volts or 5 volts depending if opened or closed and the D lever.
Pin 16 of C1 should go LOW, that is, zero volts when you "pop the top". WIth top up and secured, you should see 5 volts.
