Old Mar 13, 2022 | 01:48 AM
Exoddus's Avatar
Exoddus
Exclamation Help Please! 2007 Xfire - Dash lights on, Spoiler up, Speedometer not working
Hi!
I have an intermittent issue with my 2007 Crossfire, it has a manual transmission with ~74k miles.
The car will have a bunch of dash lights come on (see attached picture for details), the spoiler will go up without me being able to lower it back down, the spoiler button will also blink on and off.
The car will start and drive just fine, rpm gauge works fine, gas gauge seems fine, engine temp seems fine.
The window washing light is always on so idk if that is part of all the lights coming on or not and I believe the red light with person and seatbelt with the circle in the face might be the airbag light? It's usually always on also
Edit: I did a bad job and didn't put my seatbelt on when I took the picture that light goes out when it's on, also want to confirm that the brake light stays on even when the brake is not pulled.
I checked for engine codes and came back with nothing and I also disconnected the battery and let it sit for awhile and reconnected and it did not help.
I plan on pulling the RCM to inspect fuses/relays and touch up the solder joints when I am able (between houses right now and my stuff is at the other house).
Tried searching around for similar issues and found this forum post. The original poster never confirmed anybody's suggestions.
The user direwolf said in the linked post "No Speedo and Dash lit like a Christmas tree? Been there. It was the ABS module. 2¢". I'm not sure how to diagnose that the ABS is/isn't working, if someone could point me in the right direction?
Does anyone know of anything that might cause these symptoms? If more information is need please let me know what I could provide.
Thanks!
