Thread: Height of wings
Old Mar 13, 2022 | 11:32 AM
GraphiteGhost
Default Re: Height of wings
oli, did you buy it new? Was there any suspension work done by you if you purchased new? Are the tires OEM SIZE? IF someone else replies these values are not within OEM values I would suggest you check out if suspension work was done OR something failed (especially if BOTH sides are about the same as you posted, since you never mentioned this). When you check both sides, make sure the car is on a LEVEL surface! Good luck!
