Old Mar 13, 2022 | 11:58 AM
  #1964 (permalink)
dedwards0323
Here are some examples of actual logged maintenance problems, as submitted by QUANTAS pilots, and the solution recorded by their maintenance engineers. (By the way Quantas is the 3rd oldest major commercial airline and has not had a fatal crash since 1951.)
P = The problem logged by the pilot.
S = The solution and action taken by the engineers.
P: Left inside main tire almost needs replacement.
S: Almost replaced left inside main tire.
P: Test flight OK, except autoland very rough.
S: Autoland not installed on this aircraft.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S: Live bugs on backorder.
P: Autopilot in altitude-hold mode produces a 200-fpm descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for!
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windscreen.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Mouse in cockpit.
S: Cat installed
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
