GraphiteGhost
Check some posts about the brake light switch, also if your battery is failing that manifests itself with all types of system quirks. If the battery is older than say 4-5 years it probably needs replacing anyway. . Other than that I have no suggestions. Good luck!
I will look into that. My break lights come on when I hit them. Can this still be an issue if the break lights are working?
As for the battery, it's not very old and has a good charge. I charged it up a few days ago to make sure that wasn't an issue. Also tested the internal resistance of the battery by putting a load on it and the voltage didn't drop enough to suggest internal resistance was bad.
Edit: Checked battery and it's from 2019.
Thanks for the suggestion!
