Thread: Height of wings
Old Mar 18, 2022 | 04:44 AM
oli's Avatar
oli
Default Re: Height of wings
hello , thanks for your feedback .
my car is stock , and had only 80.000 km. Wheels and tyres are standard size .After changing the upper arm of suspension ( i change it because it has a slack ) , now when i turn fully the steering wheel the wheels touch the body.
correctly measure of height from tyres to fender, makes that the front is lower that the rear about 4 cm so it makes 1,5 inch .
i suppose that the car has made a jump and front arm has been damage .
i will check the front and rear height , and shock absorber condition , lenght of spring and if some part are bend.
can some one makes a measure from the ground to the jack point at front and rear on a standard car with original suspension?
regards
