Thread: Code P0175?
Old Mar 20, 2022 | 09:39 AM
UrbanE's Avatar
UrbanE
Default Re: Code P0175?
I see you posted this on the 10th and may have already corrected the issue. I googled po175 and this is what came up.
“It is important to complete the entire diagnostic process when diagnosing P0175. Many people will replace the air-fuel sensor or
oxygen sensor as soon as they get a bad reading, but the root cause can also be a dirty or faulty mass airflow sensor or vacuum leak, thus causing the O2 or MAF sensor to read differently to compensate.”
I would look for the vacuum leak first and then clean the airflow sensor second.
Please let us know when you’ve located and corrected the cause of the code I would like to know what triggered it.
