Old Mar 24, 2022 | 02:21 PM
  #7424 (permalink)
onehundred80
I changed the SC oil, I drained it very well and replaced it with a little less than120 cc (4 fl.oz)
I also changed the belt and the SC idler pulley.
The hardest part was removing the scatter shield, The clamp on the oil hose to the oil cooler had to be raised off the hose to squeeze through the gap.
Next up is the 8 way passenger seat mod and a replacement for the ABS module to see if that cures the low pedal. I read that a stuck valve in the module causes a low brake pedal.🤞
