Re: Spring pad shims
Hi,
I don't think the spring is broken, if it had been broken that side had been much lower. And when I inspect the spring I can't see that it's any wrong with it. Maybe a spring had been broken earlier and they only replaced that spring, not both.
Now I will order two new springs and two spring pad shims of 5 mm. I also order a set of front camber bolts.
Lars
