Old Mar 31, 2022 | 03:39 PM
Exoddus's Avatar
Exoddus
Default Re: Help Please! 2007 Xfire - Dash lights on, Spoiler up, Speedometer not working
Awesome I will look into those wheel speed sensors if it's not my relay. And will check out the brake light switch. Does anyone know what a good resistance reading on the switch would be with what pins?
I had just a minute to check out my RCM and I reflowed the parts of the board that needed it and that didn't fix the issue.
Was looking at the wiring diagram from a 2004 crossfire manual and it seems the Engine Control Relay and the Traction System Relay get power from the same 2D pin and go straight to ground.
I turned the ignition on while being able to look at the relays and the engine control relay did come on but the traction system relay did not.
Next time I get to mess with it I will check the resistance of the coils on the relays to see what they are and perhaps inject power to the coil to see if it activates if the coil isn't OL.
Note: I did manually activate the traction relay when starting the car and the lights on the dash did go out but the spoiler still wouldn't go down.
Does anyone happen to have a copy of the 2007 crossfire workshop manual?
Thanks for all the help!
