Old Mar 31, 2022 | 04:23 PM
Astrofriend's Avatar
Astrofriend
Default Re: Spring pad shims
If the original pad shims is only 5 mm I get a problem, I want to lower the car. Maybe in my case I have a 9 mm pad shim on left side and a 5 mm pad shim on the right side. When I get my new endoscope I maybe can see the number of ***** they have so I can plan better what spare parts to buy. I read about someone that used a 1 mm pad shims, maybe he had cut a 5 mm pad shim down.
Have a look here, the 4th photo. I measure from the center of the axis to the fender, not from ground, then the size of the wheel and tire doesn't matter. Someone who have that height from a standard car ? I have 393 mm on left side and 382 mm on right side. As you see I have a lot of air above the tire, it looks more like a tractor.
Thanks for the PDF instruction, very good !
ps.
When I look at part number for the rear springs, both standard Crossfire and SRT hase the same springs, I thought the SRT had much more stiffer springers.
/Lars
