Old Apr 4, 2022 | 01:30 PM
GraphiteGhost
Default Re: Trunk cannot open!!!
Originally Posted by meh03
I figured it out. It was all engaged and rotating properly. I took out the passenger side light and looked inside. There was a little tab up by where it rotates. I just pushed that tab up with a screwdriver. It clicked and then the latch opened.
Good you got it open, now make sure you FIX that electrical system by completely checking it out for 'melted' wiring near/around the lamp module (as you described previously in another post). If you find none, check further. Good luck!
