dogwood_laine
I have an issue with water collecting inside the convertible top frame. Any time it rains, water pools in the top rails on both sides (the sections that runs from the windshield towards the back of the car). It generally gathers right around the first "joint". When I am on an incline or accelerate moderately, it runs out and onto the driver and or passenger. Is there some sort of drainage hole that may be clogged. I am the 2nd owner of this car and it appears to have been an issue with the first owner as it looks like there has been enough water on the passenger side seat to make it look like someone peed themselves (seat has a butt sized water stain). So, again...clogged drain hole? Also, any help for the stained leather or should I just get seat covers?
SAME ISSUE HERE! After some heavy rains (not all) and upon acceleration forward this "pooled water" will drain inside the vehicle and onto either the driver or passenger's SHOULDER leaving a dark dirty and gritty water substance on their shirt! There can be as-much-as a half cup of water that deposits right onto the individuals shirt and arm either causing staining or at least the need for a wardrobe change.
Based on the various comments on this thread (either happening on the driver side only/ passenger side only/ or sometimes BOTH) I draw the conclusion it must be more drain holes somewhere on the roof that are blocked. There are many drain holes in various places around this vehicle, BUT I CANNOT FIND WHERE or cannot find diagrams ect..... luckily it hasn't happened to me in a while so either mine are clear or it just hasn't rained enough. Good luck !
