Old Apr 21, 2022 | 11:44 AM
GraphiteGhost
Default Re: Amp Plug B - BL/DG wire missing?
Best advice I can offer, download the .pdf service manual and trace the harness wiring to find out where that wire went to. I have seen that blue W/yellow stripe used in other cars as a 'ground' but with this car it is only a guess & you should NOT ground it until you research where the wiring diagram (in the service manual) leads it to. Good luck!
