Thread: Brake light
Old Apr 25, 2022 | 12:49 AM
Chooch's Avatar
Chooch
Default Re: Brake light
Recently had the ESP/BAS light stay on, even after disconnecting battery and the full right, full left, and center drill.
Having read multiple post about the ESP/BAS light on and the brake light switch connection, I checked to see if my brake lights were working... NOPE! No Brake Lights!
So, I checked Inside panel Fuse 2 - it was OK.
Then, I went through the horror of dropping the lower instrument panel (haven't done that since the Sticky Key Fix).
Got that switch out and tested it: No continuity pushed in or out = Dead Switch
So, I need a new brake light switch for a 2004 6 speed .
The problem is that the switch in my hands has tw​​​​​​​2004 6 speedo (2) terminals and the replacements I've found (Standard Motor Products #
SLS384)
show 6 or 4 terminals in their photos.
The following numbers are on the switch in my hand:
CR02 on one side
PA66-GF30 on the other​​​​​​​
03 6101 00 on the back flat
If any of you XF gurus are out there, please give an old man some guidance.
Pizza Guy has provided a lot of good tech info on this subject (and others).
Last ditch will be hitting parts stores and/or MB Dealer to get a match.
​​​​​​​Thanks in advance,
