Thread: Brake light
Old Apr 25, 2022 | 01:14 AM
Ronman's Avatar
Ronman
Default Re: Brake light
Originally Posted by Chooch
Recently had the ESP/BAS light stay on, even after disconnecting battery and the full right, full left, and center drill.
Having read multiple post about the ESP/BAS light on and the brake light switch connection, I checked to see if my brake lights were working... NOPE! No Brake Lights!
So, I checked Inside panel Fuse 2 - it was OK.
Then, I went through the horror of dropping the lower instrument panel (haven't done that since the Sticky Key Fix).
Got that switch out and tested it: No continuity pushed in or out = Dead Switch
So, I need a new brake light switch for a 2004 6 speed .
The problem is that the switch in my hands has tw2004 6 speedo (2) terminals and the replacements I've found (Standard Motor Products #
SLS384)
show 6 or 4 terminals in their photos.
The following numbers are on the switch in my hand:
CR02 on one side
PA66-GF30 on the other
03 6101 00 on the back flat
If any of you XF gurus are out there, please give an old man some guidance.
Pizza Guy has provided a lot of good tech info on this subject (and others).
Last ditch will be hitting parts stores and/or MB Dealer to get a match.
​​​​​​​Thanks in advance,
The Mercedes part number for the brake light switch for a manual transmission should be 0015450109. Compare the pics online and make sure it matches what you have in your hand
