Thread: Brake light
Old Apr 25, 2022 | 05:23 PM
onehundred80
Default Re: Brake light
Originally Posted by Chooch
0015450109 is a 4 pin switch.
Perhaps this switch might work if the plug fits the two pin socket, leaving the two round pins unconnected?
Guess I'm off to the shops and see if it looks right.
Thanks for the quick response with the part number.
I'll let y'all know if/when it works or not.
Sure go and buys part that probably will not work, if you are very lucky the may give you your money back, but not likely.
Can you not find the correctly numbered part?
Can’t you take it apart and fix it.
