Old May 4, 2022 | 05:50 PM
onehundred80
Default Re: Losing Hope: Broken Key in Ignition. Options?
Originally Posted by blazodan
I did two very dumb things. First, I tried to use my key as a lever to remove the lid from a pot. It broke. Second, I inserted the broken key into the ignition and attempted to start the car. The broken piece is stuck deep in the ignition. I removed the entire ignition and a locksmith came over to try and remove the broken key, with no luck. He said it was too stuck and since the key won't turn, it's inaccessible.
I'll probably continue to try and remove the broken key with the little lockpicking tools, hot glue, or whatever, but I don't expect that to work. I could keep trying locksmiths but that seems unlikely to work. So at this point, what are my options?
I assume it's near impossible to get a new tumbler given that it took about 15 months for a new key a couple years ago. It seems to me like I should be able to tape the fob to a screwdriver and use that as a key, but for now, even a screwdriver will not turn the tumbler. Would it be possible to replace the ignition with a used one, using the transponder ring from my car and the chip from my broken key fob? Could I somehow hot wire the car given that there are no skreem issues? It's a 6-speed '04.
Any advice would be much appreciated, thanks!
Is it not possible to take the tumbler apart? If so get a new key cut to the old broken key parts soldered together if necessary .
Or buy a new tumbler and key and have a new fob key cut to the new key, you can buy blank fobs and use the blank key in it cut to the new tumbler key.
Or if possible modify the tumbler to suit your old key.
Tumblers are not especially made for the Crossfire.
Do not try to hot wire the car that will ruin something for sure.
