Old May 5, 2022 | 02:27 PM
blazodan's Avatar
blazodan
Default Re: Losing Hope: Broken Key in Ignition. Options?
I believe the 'Sticky Key Fix' might have it mentioned but not sure, do a search and make sure it is the latest version (I believe it mentions it somewhere on the list/document). I'm attaching V6 but am not sure it is the final version. Good luck!
Thanks GraphiteGhost, but the pdf doesn't explain how to remove the tumbler from the ignition assembly. Is this possible since the key is stuck in position? Thanks.
