Old May 5, 2022 | 05:24 PM
GraphiteGhost
Default Re: Losing Hope: Broken Key in Ignition. Options?
Originally Posted by blazodan
Thanks GraphiteGhost, but the pdf doesn't explain how to remove the tumbler from the ignition assembly. Is this possible since the key is stuck in position? Thanks.
But, it DOES allow you to take that assembly to a locksmith and see if HE can open up those tumblers (or re-code an external iggy set to work for your re-keyed blank that he/she removed from that OEM iggy). If he is a locksmith that has the ability to work on car ignition tumblers (hint) then you might be gold on this... Otherwise, a different 'iggy' key cut to an ebay iggy 'set' might have you owning two keys for the car, it seems (if I understand your whole issue). Good luck!
