***Help!*** I am well versed with these Crossfire tops and how they operate but this time I am stumped. When I hold the top button put the top down it gets to the final stage which is the t
onneau cover latching with a "click sound" . (But no final beep) and then the cover slowly pops back up unlocked. Reversely, when I go to close the roof the top goes all the way the final stage but the rear window (Bow) will not travel downward. (My guess is that it senses the tonneau cover is not locked and stops). I can pull the fuse and get it to close the rest of the way and lock it with the tool. There is no data in this string about how the tonneau cover latch works. It's almost as if the hydraulics bleed backwards and the latch never fully gets engaged. (No visible leaks either) I've adjusted the height of the latch but that did not work. I can lock it with the wrench with great ease so it's not a latch alignment issue Any advise?
