Re: Convertible Top Sensors
MCPO here:
Spring has arrived in Minnesota and I now have my Roadster out of storage in in my garage. I have been driving the car and have found some new information
PROBLEMS
Spoiler with and top switch not functioning
SPOILER:
I found that when driving the spoiler activates when I hit 62 mph. Hence, I know the motor is working. However, I can not activate the spoil using the with. The switch has a steady red light.SUGGESTIONS WELCOMED!!!
CONVERTIBLE TOP: Top does not activate when using the switch. I will be checking the latch retainer switch as that was one of your recommendations. What I found out yesterday was that when I try to lower the top manually, it froze in position and I could not move top or tonneau cover. That had never happened before. I remember reading that I needed to release hydraulic pressure in the lines by turning on ignition while holding the Top switch. That released the hydraulic pressure. Hence, I assume the pump was working. While driving, hear intermittent beeping which goes off if I touch the top switch. Now, when I turn off my car and remove the key the ignition, the top light switch remains on with a steady light.Totally confusing.
I WILL NOT take my car to a Chrysler dealer or Pizzaguy would disown me......
Thanks all.
