Directional Flasher Location
Just changed the front flasher lamps to canbus LED's on my 2005. Flashing rate is now faster which I know is due to the lower wattage demand of the LED. I prefer not to install a resistor as a fix. Can the stock signal flasher relay be replaced with an LED compatible type? If so where is this stock relay located?
Thanks
