Old May 8, 2022 | 10:47 AM
Jack G's Avatar
Jack G
Default Re: Front turnal signal Europe, replacement ?
Do have access to a scanner? You should be able to build a 3D model using original. molded frame. You will need to section the lens and the frame and scan them to develop the complete model. This would also allow you to replicate the mating lamp socket attachment. Using reverse engineering techniques can greatly reduce having to redesign the part.
