Old May 13, 2022 | 07:28 AM
GraphiteGhost
Default Re: Dashcams in your Crossfire?
Originally Posted by F4celess
So, I routed my Dashcam wiring down to the “interior fuse box” on one end of the dash (with door open).
HOWEVER, while there are live fuses ONLY when you turn on the parking light, with key removed, none of these are 12V permanent live!!
So the larger fuse box in the engine bay, does this have any routes into the cabin behind it?
I understand there’s a cable route in, behind the battery, but that’s the opposite side of the engine bay - plus I want to use some add-a-fuse / circuit from the fuse box (other side)!
Any clarification would be appreciated.
The downloadable Service Manual is your friend for the wiring harness diagrams. It involves some reading on your part (also to mention there are some but not many errors in the manual), you'll have a basis for finding the "Always ON" wiring in the dash which is easily testable with a voltmeter with the almost 100% accurate color coding (again cross-referenced) in the Service Manual. Good luck!
