phil alvirez
a suggestion:
when you arrive from a ride, open the hood and touch the engine. or just get your hand close to it.
the air flow through the engine bay may be good when the engine is running, as air enters and flows through the engine and components, and exits through the rear. this is fine, as long as the car is in motion, or even if stopped but with the engine running, the fan will take care of it.
but as soon as you stop the engine, as the air tends to go up when hot and there is no opening anywhere up, it just stops flowing (another drafting board engineering failure).
anyway, just check it, and even measure the temp. and if you left the hood down, that heat may damage components. any. particularly rubber or plastic. and seals. anything.
and even if you open the hood, if it is under the sun, it remains hot forever.
dont believe me, measure the temps.
perhaps a simple solution may be when you reach a destination, to open the hood until it cools off. and if the sun hits it, place something as a spacer and close the hood partially.
that is what i do, and it cools off dramatically.
i hope this helps.
With the car stopped and the engine off the engine will start to decrease in temperature, slower than if was running downhill with the engine off, but still cooling.
I think that materials liable to be damaged by heat too soon are not used, having been replaced by more suitable materials.
We do not let that heat go to waste, we use it to cook dinner on a long trip, there is nothing like the smell of roast beef and baked potatoes in the cabin as you drive.
Why don't you see what Wiki says about it and post any answers on the Skoda forum, they will love to hear I am sure.
