Re: Crossfire Smog pump \ Secondary Air Filter
Most likely code P0410. Check the contacts on the air pump relay in the relay control module. Bet that they are BURNT! May have been your problem all along. If so the relay can be replaced for about a third of the cost of a new RCM.
There's also a blue check valve that can cause issues.
