Re: Electrical problems, brakes, brights,
Deepsea21
I think you have separate problems going on that are not related. The brake lights and no high beams are separate problems from the BAS/ESP lights. Start the car, drive it around, without re-setting anything, take a pic of your dash and post it so all can see what indicator lights are on.
Then burnt bulb indicator goes on and off on ride as well. Just replaced giant yellow fuze under hood, driver's left side.
I have a hundred dollar scan tool, only says 02 sensors. Cats are deleted. No other codes are being thrown. I have seen posts regarding a special 0B2 tool to use and not any regular one. I don't know if this is true. Just took off dash again to reinstall the brake light switch. I'm thinking 🤔 ..maybe I should check all these electric connections, I do have a multimeter, but am not familiar with using that well.
Now the right blinker is acting up. Lordy! Sometimes it doesn't work.
