ZERACER
If you accidently downshift you should also just be able to push the shifter to D+ and it should just shift back up, like a stick shift unless you are going to slow for the next gear.
It will shift back up, but once you have moved the gear lever into either "
D-" or "
D+"
the transmission will remain in "MANUAL" mode until you either (1)
restart the engine or, (2)
HOLD the gear-lever in "D+" until you see the gear position indicator on the dashboard indicate you are in "D" again.
