dog dalisera
i am having the "no start " issues. sent out the skreem to be refurbished. came back, same problem. sent it back & they said it checked out OK. next , took out the RCM, it looks perfect. the soldering looks great. is there anyone in the metro NY area that knows my 2007 crossfire limited ? HELP.....thanks Dog
Is it cranking or no crank ? Relays could be back if it’s not cranking. If it’s cranking and not starting could be your crank position sensor, cam position sensor, or maybe fuse #30 or #32 ?
Also if no crank, verify ur ignition is sending power to your clutch switch and your clutch switch is sending power to the pulse module !
