Old Jun 26, 2022 | 07:11 PM
tighed1's Avatar
tighed1
Default Re: No Crank, No start. Possibly SKREEM #3 ?
Originally Posted by dog dalisera
cranks over 2-3 times then nothing. had the skreem sent out...fixed, then re-checked. how do you test the RCM ? Or do crank position sensors have the same symptoms ?
Open the RCM. Reinstall. Turn key to the ON position. 2 of the 3 middle relays should remain closed. The fuel relay should close for 2 seconds, then open, when the key is first turn to the ON position.
