Re: Ignition Key Will not turn?? 2005 Coupe
[QUOTE=BibaResto;769216]onehundred80, thank you. Once again you've 'come to the rescue'. pdf is filed away
I just did this mod on my 2004 with 36,000 miles on it. Locked up in driveway. Followed the .pdf, took about 1-1/2 hours. Worked as advertised.
Here's my question...if removing that spring and pin behind the door fixes it...which it does...why the hell do they have the damn soring and pin there to begin with? What does it do? All the other functions work without it, so why did they even put it in the assembly? Stupid...
