Old Sep 26, 2006 | 05:31 PM
Idaho's Avatar
Idaho
Default Re: OIL Change at 7,000 miles
I originally agreed with BRappaport, that the only way to properly change the oil was drain it out the oil pan. However, after doing a little checking around and experimenting with the TopSider I agree with X-fired and use the TopSider and change my oil and filer every 4k-5K miles. I found out that most of the dealers now use vacuum method and through my own experience I have found that I reclaim more oil using the TopSider. I am assuming the reason I am getting more oil is because the ramps have the car at a slope when I drain the pan. By the way I initially found the first mention of using the TopSider on the MB forum. Personally, I don't think either method is going to jeopardize or extend the life of your vehicle. I believe the key is frequent oil and filter changes so that the contaminates are suspended in the oil and get deposited on the filter.
