Old Jul 4, 2022 | 12:46 PM
GraphiteGhost
Default Re: Instructions on how to replace alarm siren
Originally Posted by nickwe21
Thank you to all of you. I took off the panel underneath the windshield wipers on my NA this weekend to clean all the debris and make sure the drains are clear. With your help, I was able to see the siren. Went ahead and ordered the updated one with the chirp from Bosch.
So once it gets here I'm going to install it in my SRT Roadster. But man oh man was it a ***** to remove those windshield wipers 🤦‍♂️🤦‍♂️🤦‍♂️
Yes, quite the experience. When you reassemble, be real careful where you place the tubing and wiring you removed/moved. You do not want to 'pinch' either. One may result in squirting fluid where it doesn't belong, the other may result in a blown fuse somewhere.
