Old Jul 4, 2022 | 06:43 PM
onehundred80
Default Re: Instructions on how to replace alarm siren
Yes, quite the experience. When you reassemble, be real careful where you place the tubing and wiring you removed/moved. You do not want to 'pinch' either. One may result in squirting fluid where it doesn't belong, the other may result in a blown fuse somewhere.
The nozzles can be cleaned in place just by unclipping cover and adjusted with a pin in the nozzle hole when they are clipped back in place. It is a good idea to run some fluid through the tubes before putting the nozzles back in place.
