Chrysler Crossfire Central locking - Locking but not unlocking with fob
Hi Guys,
I am located in Queensland, Australia. I have a 2004 Crossfire with 60xxxklm.
Recently the key fob stopped unlocking the vehicle. I have replaced the battery in the fob. When I press lock, it works and locks the vehicle. When I press unlock, the car lights blink but it doesn't unlock. I can use the key to unlock the driver door, this sets the alarm off. If I press lock on the fob, the alarm stops. The car starts and drives fine. If I reach over from inside the car and open the passenger door the alarm will go off and sometimes it will also unlock the boot.
The air pump in the boot seems okay.
hooked the car up to a scanner and got: CAB internal failure - low pressure feed valve 1. CAB internal failure - low pressure feed valve 2. Pressure sensor electrical error.
Any ideas?
