Old Jul 16, 2022 | 10:28 AM
  #47 (permalink)
zip439's Avatar
zip439
Default Re: Ignition Key Will not turn?? 2005 Coupe
Originally Posted by CobraSwede
Thankś a lot !
I found it, but even then it was too tight to get assembly out.
I will probably choose a solution with a separate switch+starterbutton.
Zracer is right, and there is more to the ignition switch than just starting the car. There is a locking mechanism that prevents the gear shift lever from moving, I don't know how you would by-pass that and also an anti-theft device.
