Thread: Fuel pressure
Old Jul 26, 2022 | 10:04 PM
austinbarrylee's Avatar
austinbarrylee
Default Re: Fuel pressure
Originally Posted by amx1397
" I am running 62" 62 what? fuel pressure.
not sure what info you want but i don't have the 550 injectors but do hold the record for the world fastest crossfire.
if you have a afr gauge, don't go any higher than 12.5 afr reading. don't forget your fuel pressure has to overcome your boost, air pressure into engine, to make the engine run great so if i were you, i would get (if u don't have one) a afr gauge. and set my fuel pressure with that. hope that helped jim
Thanks Jim. I'm running 62 pulley. I have my fuel pressure on the rail set at 59. Is this going to run lean. I don't have afr gauge yet. It's hard finding someone to install it Here where I live. I getting the tune installed this weekend. I have the pressure set at 59 and was wondering is it safe to drive until afr gets installed.
