WingMan
Thanks, all for your guidance. I’ve managed to persuade a leery Merc mechanic to at least look at the issue. I have the pics and the relevant service manual pages set up for him (8Q - 53 & 54). Since I, the non-mechanic, have to guide this mechanic, I’d like to confirm. As I understand it, the process is: remove the wiper arms, remove the cowl/grill. The siren/alarm is dead center between passenger and driver, tucked up against the firewall. Unplug the wire, unbolt and remove the siren. Reinstall the cowl grill, reinstall the wiper blades.
Did I get that right?
That is correct; While the cowl is off clean the area as it often gets leaves under the cowl, blow out the four drain lines with low pressure air.
