Thread: Misfire?
Old Aug 4, 2022 | 10:37 AM
zip439's Avatar
zip439
Default Re: Misfire?
If a plug isn't firing you should get a couple codes. misfire knock, ignition coil, I would suspect your problem is a vacuum leak or the MAS Mas Air Flow sensor. That is just a guess, but they should all show a code. First thing is to double check your past work.
