Old Aug 4, 2022 | 11:55 PM
Sik Srt-6's Avatar
Sik Srt-6
Default The ultimate no start issue
Hey folks. so what entails the ultimate "no start" issue. lol
Well my situation is probably one of the most awkward no starts in existence that i have stumbled upon. Its gonna be a long synopsis, but i hope i can finally get to the bottom of this.
So heres the jist of it.
My car is low mileage.. under 20k mi.
I had the odd little issue with the alarm module back in 2018, which was fixed with a new alarm module (common battery leakage issue).
End of 2019, literally a week before storing the car for winter, i had this random no start issue (turn key dash comes to life as normal but no crank, no starter energization.). i realized it was likely a old battery (original since i owned the car; 8 years at that point). and surprised it even lasted that long, keeping it on a mantianiner really extends it life.
Anyways, parked the car for the winter with it on a battery maintainer in a climate controlled garage until end of 2021.
End of 2021, with the original battery, car wouldnt crank for the few first times (no starter engagement, but battery was not weak or low charge). then after a few minutes of fussing around, car started, but was in limp mode, and had to use the interlock tool to allow shifting into drive/rev.
Did a RCM re solder, did not solve any issues but there were visible solder cracks (gotta love the 2000's ROHS garbage).
Swapped in a new battery and issue seemed to have gone away. Likely a module needed a restart by disconnecting and re-connecting battery. All was good, or so i thought.
end of 2021, decided to store car again, but with battery disconnected/removed because i ended up keeping it on a maintainer away from the car with all my other batteries that get charged during our downtime winter.
Fast fwd to today.
Uncover car, and get it ready for atleast a few months of summer enjoyment. Drop new charged battery in. Key in, everything seems normal, but back comes the same no start when key turned (no starter engagement). Dash and everything else comes to life as normal.
A bad skreem moduel supposedly allows 3 starts, but then stalls. I am getting absolutely no response at all.
Even without the car starting, the transmission shift interlock is still not dis-engaging which is odd even when turned to key position 3 (acc), and brake pedal depressed.
Pulled out pulse module (starter and inter-cooler pump relay), checked for solder cracks, none to be seen, re soldered all connections to be sure). Same no start issue.
Heres the kicker....
With Key in 3 (ACC), and manually pressing starter relay on pulse module, engine starts and runs!
But car is clearly in limp mode with the dash lit up like a christmas tree.
Things to note, when running, brake lights are not operational (turn signals and driving lights are all working), and transmission is in limp mode, engine runs fine. The park/neutral ~3000-3500 rpm rev limiter doesnt seem to be enabled which is also interesting.
In the next few days ill be getting my witech micropod DRB 3 emulator going and seeing if i can try and diagnose any issues that route.
My possible suspicions.. (still looking over wiring diagram to reverse engineer, cant find the shift interlock solenoid anywhere to use as a starting point)
- defective module on canbus line causing erratic noise?
-power feed issues to BCM?
-bad solder joints other then on RCM or pulse module.
Any others have any ideals for more in depth higher level troubbleshooting. Always a fun ride with this car.
