Thread: Misfire?
Old Aug 7, 2022 | 11:42 AM
GraphiteGhost
Default Re: Misfire?
Originally Posted by bc75
I was having a misfire code. I changed plugs and wires. Thought i fixed it but it came back. I found 5 of my coil packs had a crack in them.
This post reminded me of a commercial... " You say, you have a crack in your coil pack... I just want to say, heyyyy..." I think it was a commercial for windshields. Anyway, leakage during high engine demand (hard acceleration) would def cause misfires. Depending on where in the pack the crack is, it could easily be a lot worse. I would change all 6 since it seems that run of coils are bad (unless you're in a super-hot state and the car is running exceptionally hot). You might also see what you could do to cool down the engine compartment (if possible). Good luck!
